J. Elstner
- Jul 10, 2004
- 4
My drive belt broke. Can you run me through how to replace it?<br /><br />Thanks,<br /><br />Elly
I have a 1994 Mercruiser alpha 1, 3.01 ltr., 4 cylinder, inboard. I need help changing the altinator belt closest to the motor. There is a bar in the way????? THANKS!!!!Originally posted by WillyBWright:<br /> As I recall you have to support the engine and remove the front motor mount. Hopefully you have the means to hang the front of the motor. A sturdy piece of lumber between the gunwales and a chain with a load tensioner that semi trailers use could work. You shouldn't need to lift the front, just relieve the weight so you can get the mount on and off. Some people put a spare in position and attach it in a way so that it can be moved into place without having to remove the mount should the need arise again.
