OMC 3.0 Running rough
Mr Wubbs
I have 87 OMC 140 with a Rochester 2 GC. The carb was rebuilt as well as the motor by a very good shop. I am having issues with the motor idle being very rough at times and hesitation as you increase RPM. I am also seeing the plugs are getting black fouled.
The motor starts up on click.............does not stall just has a rough idle.
New wires, New Pertronix, new plugs
I have checked all ignition and wiring, pumped all gas from tank and installed new fuel pump and filters. I have also removed the shift interupter for test and no changes.
I have taken the boat out and it cannot run for more than 1 hour without coming to a stop.
ANY IDEAS ?
Mr Wubbs
Re: OMC 3.0 Running rough
I just replaced the carb and it seems to be running the way it should. I got it from a place in Atlanta GA that builds to order.
If you have a marine carb and what it done RIGHT call this place
CARB JUNKY http://www.carbjunkys.com/
Tell Jim Art sent you !!
He does them right at great prices !!!
