I got a boat from a relative for almost free, and when i started it up in the driveway I see its got a crack in the block and was leaking.I patched the outside crack and started the engine up again and then checked the oil, and it has water in it, milkshake looking. I plan on pulling the engine to see if the heads are Ok , but I am not sure what type block i need to replace the one on the 3.0L cobra OMC.Can anyone give me some idea is it a Gm or Ford? The boat is a 97 caravelle, can you use the block froma auto/truck and fit it up to the heads ? Any help would be greatly appreciated.
Buzz
Buzz
