OMC 4.3 fuel and electrical issue
Status
Not open for further replies.
Lakes84
OK, First off, I've done a TON of reading and searching, then reading some more. I think now I have more questions than answers.
I have an 87 4.3 OMC with the Cobra outdrive. Before I purchased this boat (Sport Craft) I did my due diligence and had the whole thing gone over. It was said to have bad gas in it. Well the gas tested out fine. What it needed was a good tune up. New cap and rotor, points condenser...everything. The Marina said the boat ran great and it does, but when I put a heavy load on it, say 50% throttle, it will die. So, what I could glean from past posts was the problem could be anything from the fuel pick up on the tank, to a clogged fuel filter, either in carb on or the inline one, pcv valve, dirty gas or maybe even the fuel pump itself. When the motor dies, it will start again shortly there after and idle fine, then history repeats itself. Giving it some gas, seemed to help a little, but it would eventually die again. I understand the bowl is being emptied quicker than the fuel system can fill it, thereby causing this issue..... That's also a guess, but I think a pretty good one....Am I on the right track with that assumption?
However, after going through this process 3 or 4 times, I went to start the motor again....then nothing, no clicking, no noise, nothing. The gauges all were silent, so me thinks there's a fuse somewhere that has tripped, but I'm not sure where. My friend who owns the resort we stay at, says theres a 50 amp fuse on the Mercruisers, that is on top of the engine in plain site, that sometimes needs resetting. We couldn't find that on mine, anywhere. There are two rubber boots on top of the engine close by the lower unit solenoid, that he thinks has fuses in them, I'm not so sure. Everything else works on the panel, blower, lights, bilge pump, so I know the batteries are good. Possibly, I was thinking the key switch might need to be replaced, or maybe a ground somewhere...engine compartment for that maybe?
I can trouble shoot computers all day and get them fixed. I need to reeducate myself on the finer points of "old" engine maintenance. Any help or pointers I receive on the way are sincerely appreciated.
Joe
Lakes84
Re: OMC 4.3 fuel and electrical issue
Well, the more I study this stuff, the more I think the issues are related and more than likely are one in the same.....electrical
Lakes84
Mmmmm. Absolutely no one has any ideas on this? Really?
open up those rubber connectors and see,. there should be a 50 there somewhere( a large wiring harness)
bruceb58
First place I would look as at the starter where all the connections are. Not only does the battery cable go there but the wire that feeds your entire electrical system originates there. Take all the cables off and make sure they are all shiny clean and reinstall.
Once you do that you can start checking voltages as Howard states.
mark.brannon
Joe
I have a 96 Volvo Penta (similar to OMC) and had the exact same problem--when I would turn the key....nothing. After doing some research, I found that it was an assist solenoid that sits on the front of the engine. Mine was enclosed in plastic. It was a $10 or so part.
Lakes84
Thank you Mark, I'll see if I can find it on mine. Much appreciated.
Joe
Knoll42
OMC 4.3 fuel and electrical issue READ THIS I hope it helps
I had a similar experience this week. I was out on the water and the key stopped working no power no clicking no nothing. I got under the dash and there was a 14 amp fuse blown in line after the key switch to the motor. I replaced the fuse and got starting power but my issue turned out to be further down the line with the alternator/ Regulator. Howard helped me with some advise but I havent got the parts yet to completely fix. Hope this helps
Casey
Lakes84
Re: OMC 4.3 fuel and electrical issue READ THIS I hope it helps
Casey
Thanks for the reply Casey....I thought a fuse as well. I did find the problem. The main ignition harness was ever so slightly loose. When I tightened it back up, she started and ran well.
My guess is, when I was out on the water in some rather rough waves, the harness got jostled enough to kill the motor. then I could get it to start again. After this occurred 3 or 4 times it just stopped working because the harness did not have enough connection. Anyways it runs great now.
Thanks for the input guys. This little issue has taught me a lot about my engine and trouble shooting in general.
See you on the lake.
Joe
Status
