Omc 4.3 stringer transom seal question
d_carter
Hi has anyone tried to replace the transom seal without removing the outdrive? mine is starting to weather crack and wondering if it can be done. I tried a search but could not find anything. Thanks Don
superbenk
Re: Omc 4.3 stringer transom seal question
It can be done if you slather a bunch of soap on the drive to lube it up. That being said, it's easy enough to take a Stringer drive off that I'm not sure why you wouldn't for this job. One tear in the new boot & it's ruined. Not sure I'd want to risk it.
southkogs
Ditto - I wouldn't want to risk that either.
d_carter
I did not realize it would not stretch easily. I will pop it off and go at it that way. Thanks don
run2car
Can be done without removal but it's not worth the risk. 25 minutes to remove the drive.
menace two
It slips on very easy if you use a cut up plastic juice bottle to help it shoe horn over the bottom of the outdrive. Very little stretching involved.
