OMC 4.3L engine with electric fuel pump and safety switch installation help.
houstonnoob
OMC 4.3L, I am converting from mechanical fuel pump to electric fuel pump because the rebuild block I got now does not have a mechanical fuel pump slot hole.
Please look at my installation diagram base on my research from the forums. Does that look right? Also on the ignition (I), where do I hook them to? Do I connect this to a safety switch (I) to something like an ignition coil + side of the ignition?
bruceb58
Re: OMC 4.3L engine with electric fuel pump and safety switch installation help.
Just hook it to anything that has 12V while the ignition is on. If you have a points ignition, it will be to the ballast resistor on the opposite side of the coil.
