Re: OMC 400 and 800 Lower units
good eye. You do not want that one.
The rectangular anode is only found on 1982-1985 mechanical shift which uses a specific shift cable, shift converter box and ESA system on the engine ignition system..
1978-1981 were hydro-mechanical shift. The worst of the worst really, the hydro mechanism was prone to rust and failure if water ever got into the lower unit...and as you found out, that's not a rare occurrence in a lower unit.
Also the cable is different.
If you put your location in your profile, someone might recommend a local place to look for one.
