1984 OMC stringer drives overall ratios (from OMC manual and Seloc agrees):<br /><br />The 3.8 (170 or 185 HP) uses 1.77 overall<br />The 5.0 (230 HP) uses 1.5 overall<br />The 5.7 (260 HP) uses 1.41 overall<br /><br />so far the trend is looking sensible...there's a different chart for high altitude so no confusing those<br /><br />But then, the 2.5 (120HP) and 3.0 (140HP) use 1.71 overall... which is in between the 3.8 and 5.0's ratios...<br /><br />And earlier year 2.5/3.0's used a 1.64 overall ratio.<br /><br />I gotta go think about this some more.... I'm thinking something's being done to try to save the life of the splines of the w/p shaft by keeping speed up in the upper.... and then using lower to turn into torque... off to look at upper ratios vs. lower ratios....
