OMC 460 HIGH IDLE AFTER HEATING UP
rusty bolts
HELLO , THE PROBLEM I AM HAVING IS WHEN I HAVE BEEN RUNNING AT ABOUT 3500 TO 4000 RPM FOR LETS SAY 15 20 MANED, THEN I THROTTLE DOWN THE MOTOR IDLES AT 1100 AND I CANT KNOCK IT DOWN UNLESS I OPEN THE COVER AND PUSH ON THE CARB LINKAGE. the CARB HAS BEEN REBUILT .AND NORMAL IDLE IS ABOUT 550 600 RPMS MOST OTHER TIMES iHAVE. THE SOLIC BOOK ,BUT HOW WOULD I ADJUST THE THROTTLE CABLE OR, SHOULD I REPLACE IT .THANKS
