Trevthefox
- Sep 25, 2018
- 101
Hey guys,
I'll be doing a timing procedure on an 89 460 King Cobra pretty soon. I know I'll need a dwell meter to set dwell and a timing light to adjust timing, however the harmonic balancer or crankshaft damper on the engine is very rusty on one section, which happens to be the section where the grid used to be. I've tried to sand it a bit but can only faintly read 0 BTC with no mark visible.
I'm pretty sure the grid is completely gone by now. I've checked for used parts with no avail. Is it possible to remove and replace that part with a newer aftermarket damper? Or could I just buy a used Ford damper off of an auto?
Let me know what you think.
Thanks in advance for all your help!
