Have had issues for a few years now, boat runs good for a bit, then has trouble reaching WOT, will bog and surge when trying to achieve WOT. I’ve replaced nearly the entire fuel system, with no real improvements, other than slightly. Pulled my distributor cap today, boat has a pertonix flamethrower 2 coil, and pertonix igniter 2 kit in the distributor. I found that the pertonix plate was corroded a bit. The springs were rusted but weights appeared to move freely, and the shaft had some play in it. Do I just need to get a whole new distributor?
