have an'85 omc 5.0 with stringer drive. This season have replaced heads, intake and exhaust manifolds, and carb(edelbrock 1409). Took it for first time and it ran great except that after about 10 min. and 3/4 throttle the temp started rising and rising; i shut it down butit did not seem to be ovrheating; started it back up and got going and temp rose all the way then gauge came down quickly to @ 160 degrees. Was fishing and drifting and i had no problems but on way back to dock , again after about 10-15 min of running near full throttle , the gauge started rising almost to 240 but engine did not give signs of overheating then i backed off on throttle a little and shortly after gauge dropped quickly to about 160. i replaced impeller last season and thermostat this season. Could it be the gauge or bad thermostat? When i completed the engine , I had it started and idling in slip for about 20 -30 min and temp gauge acted normal
