OMC 5.0 outdrive upper unit replaced
justpennys
First time running after replacement overheated had impellor replaced, now doesn't overheat at low rpm, but at higher rpm's jumps up to 200+degrees
Boatist
Re: OMC 5.0 outdrive upper unit replaced
We need to know what unit you are talking about. Is it a stringer pre 1985 or a Cobra 1985 to the end.
If this is a salt water boat check the exhaust manifolds and risers for blockage.
justpennys
cobra 1992 w/5.0 ford
