OMC 5.7 cobra, carb (mod) from Holley4160 to Edelbrock(1409)
SleeplessDream
I have a 1990, OMC 5.7 Cobra (GM350) with Holley carb 4160, I installed an Edelbrock intake manifold performer with 1409 Edelbrock carb (nice fit). Need advice, parts# and resources; The fuel line is opposite side location, the fuel throttle linkage does not match/ not align with new Edelbrock carb 1409. Please prove advice and point me to parts needed, videos or pictures with links is greatly appreciated. Thank you so very much.
Lou C
For the fuel line you might have to use a flexible line with a banjo bolt type set up. This will allow the fuel line to clear the shifter bracket/bell crank
Scott06
This page has a couple universal fit throttle cable brackets and fuel lines that could go from the fuel pump to carb. https://www.michiganmotorz.com/prod...rs-renew-kits/throttle-brackets-miscellaneous
another option is the merc throttle bracket part number 805359T used for weber/ edelbrock carbs. Might fit, its what i used on my mercruiser 5.0 when i swaped the 2 bbl for a 1409. https://www.boats.net/product/mercu...MIqoihibeQ7wIVCvCzCh1mwAYwEAQYASABEgISifD_BwE
i dont know what the omc cable looks like but would imagine it would with some light fab work
