Omc 5.7 flywheel
jeremiah89
Can anyone shine some light on what flywheel i would need for a 5.7 omc I don't really have much info on the motor i bought thr boat used. From some research I've done it seems like a 168 tooth flywheel. Thanks in advance
Ayuh,..... It depends on where the holes are drilled in the block for the starter mounting bolts, 'n which flywheel will fit inside the OMC flywheel cover,....
jeremiah89
They are across from each other not side by side
Ayuh,..... It's either straight across, or staggered across,....
Nothin' side by side,.....
If they're staggered, the 168 tooth is needed, but still has to clear the flywheel cover,.....
If they're straight across, the 153 tooth flywheel fits,.....
