Omc 5.7 smells like gas in oil
Ppichey
Hi there,been having motor trouble since I took the boat to a “mechanic”to have my valves lashed last year,after he did this I have rough idle and sounds like it’s missing,oil on dipstick is at the right level but smells like there is gas in it,any idea where I go from here?thanks in advance!!!!
first, is there fuel in the clear tygon hose coming from the fuel pump - yes or no?
If yes, you need a new fuel pump
if no, is there fuel pooling in the bottom of the intake from the welsh plugs? yes or no?
if no, then change oil and monitor. if it happens again, it could be fuel pump has ruptured internal diaphragm and the tell-tale hose is plugged up.
Ppichey
I put on an electric fuel pump last year and was running good until all this from carter,still check the same?
Ppichey
It looks like it just goes through a relay,I know it’s marine but I didn’t hook it up
Ayuh,..... Bring it back to 'em,..... They got the valves too tight,.....
Ppichey
Thank you for the responses,I will let you know what I find out,have to go somewhere else,he doesn’t work on boats anymore,just cars,think he was just trying to make a buck and didn’t know what he was doing
kenny nunez
If you turn on the ignition does the electric fuel pump start running, it is not supposed to. That is the purpose of the safety switch, it is only closed when there is oil pressure.
Ppichey
Yes it is wired to the key switch I believe
Ppichey
Well ,finally figured out what is going on with this motor,apparently the “pro” caused detonation in number 8 cylinder and burnt one of the valves,have a marina fixing the problem now,thank you for your responses!figured I would let you know what happened!
