Redrig
Master Chief Petty Officer
- Oct 13, 2009
- 860
Hey all ,
I have a quick question on the ESA for a 800 stringer .
I have been reading up on various threads about the operation of the ESA , I know its supposed to stumble the engine down when its activated to about 450ish RPM .
On mine when I depress the switch It certainly stumbles the engine , to the point it kills the engine if I hold the switch.
f I just "tap" the switch momentarily the engine stumbles and goes back to normal (doesnt die)
so my question is - if you guys hold the switch down for a couple of seconds will it kill your engine ? Or do I have a bad ESA ? There is no way my engine will stay running if I hold it for longer than say 1 second. (idle about 650 and in good tune, new points , timing is right, etc)
Or is mine working correct and the shift happens fast enough that the end result is just just a "tap" of the switch ?
thanks much
thanks much
