atx111
- Oct 13, 2009
- 145
Ok, even though I got rid of the boat, this has been driving me crazy for the last couple of weeks, and sorry this is so long. My '78 Cobalt with a Ford 351 and 800 Stringer drive was running great(of course) until we were cruising along and the engine started to sputter and lose power. I immediately checked the temp gauge and it was past 240 degrees( I had only looked at it 30 seconds before and it was fine). Before I had a chance to do anything, it stalled out on me. Opened the engine compartment, it was hot, smelled hot, and couldnt even think about touching anything.
After letting it cool overnight, I went to at least see if I could get it started. It would crank over fine, but not start, and it would backfire through the carb when I was cranking it. Went and grabbed a mechanic at the marina just to see what he thought. I told him what had happened, and after about 20 minutes he got it started. It ran horribly for about 20 seconds then dies again The mechanic checked and said ignition system was gone. I knew that whatever was going on, I knew wasn't good even with my limited knowledge of marine engines.
The impeller was replaced last fall with winterization and it never ran hot up until that point. We ended up deciding to ditch that boat for a new one, reasons being that I didn't want to potentially spend alot more money on an old boat than I already have, especially one with an obsolete drive that would cost a small fortune to fix unless I knew how to do it( I don't) and had a source of used parts(I don't). I'm not bashing Stringers at all, I just wasn't interested in the potential headache it could bring.
My question is, then, even though I didn't want to mess with it at the time, what are the best and worse case scenarios for the potential damage to the engine that occurred when it overheated. I know its a moot point now, but its just for my knowledge. Thanks!
