OMC 800 Stringer on plain
THE BEEF
OK would you please tell me on your select trim gauge, when the needle is up and saying bow up is the front of the motor raised up causing the drive to angel towards the transom?
Beef
up is up - tilting away from the transom, raising the prop and drive (lowering the nose of the motor), angling the prop up, which would push more on the stern, lifting the bow. down is tilting in toward the transom, lowering the prop and drive, angling the prop down, lifting the stern and lowering the bow.
when you take off, all the way down, as you come on plane, raise it up until the boat starts to porpoise, then bring it back down a slight bit. if you have more weight in the bow area, you may need to trim up a bit more. on my boat with the stringer drive and the prop I was running, the happy place on plane was between 1/4 up and 3/8 up unless we were fishing on lake erie, then with the extra weight in the front, it was up about 5/8 the way.
southkogs
... AND (assuming you have the jackscrew type of trim on the front of the engine), the needle is indicating the attitude of the drive. But the engine will trim down at the front in order to change the attitude of the drive "up." <== just for clarity of what is being indicated vs. what is mechanically going on.
