OMC and Volvo Penta Ignition Module (Part No 3854077)
Status
Not open for further replies.
Thought this info might be of use
IGN MODULE *** NO LONGER AVAILABLE******
Name ____________ SKU ________ Superceding SKU
IGN MODULE GM __ 3854077 _____ CURRENT
Ignition Module _____ 0987194 _____ 3854077
replaced by Ignition Module (PERTRONIX P/N 1589) (#IG1589)
2014/05/omc-and-volvo-penta-ignition-module-part-no-3854077/
Daniel
1993 four winns 180
omc 4.3
mtboatin
I know this is a super old post but running into same issue with my '97 7.4 GL PMDM. Same VP pickup 3854077. How did this turn out for you? What was involved in replacement? Called PerTronix and they claim they have no listing and can't recommend the 1589. Hopeful.
Fun Times
It's going to be pretty doubtful daniel nicholson will see this anytime soon as he hasn't been back online since Jul 16, 2019 plus this thread seems more of a public info type page for future references which is why it's asked to please create a new thread of your own... If daniel shows back up then hopefully he'll send a private message letting you know the circumstances.
Before closing this thread due to its age, I'll add as a further note to the questions regarding Volvo Penta part number 3854077 that it seems there is a kit that may work for a lot of engine models as noted in the following Ebay link,
Replacement PRESTOLITE 65-190 IGNITION MODULE 3854077 3854025 855845, + Coil​
https://www.ebay.com/sch/i.html?_ss...rtronic&_oac=1&_trksid=p4429486.m3561.l161210
Replacement for
PRESTOLITE 65-190 ELECTRONIC IGNITION MODULE 3854077 3854025 855845,856143 this easy to fit kit replaces this now obsolete part, can be fitted in a couple of minutes, no extra wiring involved
Up rated sports coil included
Please note this DOES NOT include the distributor this kit is made up with the following parts
1, Black ignition Coil
2, External green Module bolted to the coil
3, Internal pickup sensor fitted to top plate (this fits inside the distributor)
Picture shows the original Module and our replacement module, our part replaces the original and will not look like the original.
Please note we are always improving our products we may at any point in time change the design for the better, if the product received does not look the same as the image this is because we have made an improvement, please contact us if you need any help fitting the kit
We can supply from stock New Reconditioned and Used distributors, we also offer a test repair rebuild service for any distributor.
Not sure if your distributor is faulty, we can test it for you, we do this free just pay the postage back, if faulty we can repair it, it cheaper than buying a new one
Please contact us it you cannot find the part you need
Compatibility
EngineYearCCEngine Code
VOLVO Marine - 430; 430A; 430B; 431A; 431B; 432A; 434A; 500B; 501B; 570A; 572A; 740B; DP-A; DP-A1; DP-A2; DP-C; DP-C1; DP-C1 1.95; DP-C1 2.30; DP-D; DP-D1; DP-D1 430; 430A; 430B; 431A; 431B; 432A; 434A; 500B; 501B; 570A; 572A; 740B; DP-A; DP-A1; DP-A2; DP-C; DP-C1; DP-C1 1.95; DP-C1 2.30; DP-D; DP-D1; DP-D1Jan 1960 to Dec 2019
VOLVO Marine - Penta Engine AQ205A AQ205AonwardsAQ205A
Original OE Part Numbers
Crusader 41090
Ford E5JL-12100-CA
OMC 987194
Pertronix 1589
Prestolite Marine SAEJ1171
Prestolite Marine SAE-J117
Prestolite Marine SAE7808BS
Prestolite Marine J1171
Prestolite Marine IG-1589
Prestolite Marine IDU781H5L
Prestolite Marine IDU-7801
Prestolite Marine IDU-3003B
Prestolite Marine FOJL121200CA
Prestolite Marine F0JL121200CA
Prestolite Marine BJM1589
Prestolite Marine 856846
Prestolite Marine 856143
Prestolite Marine 855932
Prestolite Marine 855845
Prestolite Marine 7808BS811
Prestolite Marine 7602AS
Prestolite Marine 7020S
Prestolite Marine 65-191
Prestolite Marine 65-190
Prestolite Marine 3854077
Prestolite Marine 3854043
Prestolite Marine 3854025
Volvo Penta 856794
Volvo Penta 856143
Volvo Penta 855932
Volvo Penta 855910
Volvo Penta 855845
Volvo Penta 855705
Volvo Penta 841926
Volvo Penta 841926
Volvo Penta 3854077
Volvo Penta 3854043
Volvo Penta 3854041
Volvo Penta 3854040
Volvo Penta 3850521
Status
