Omc breaker plate
Omc captain
I have 1987 omc 3.0. While adjusting new points I overtightened screw and stripped hole in breaker plate I installed a larger diameter screw that I cut to length. The larger screw is tight but I don't want it to loosen up on lake. Any ideas cannot find breaker plate to replace
gm280
:welcome: Omc captain to iboats. Nice to have you join us...
There are a few options. You can us an inside star type lock washer under the screw, and/or use some Lock Tite as well. It will not work loose unless you force it loose again. JMHO!
joeanna
heli-coil's work good, and I hope you tapped it first,
