buffyporson
- Mar 24, 2011
- 4
My 1989 OMC 2.3 is extreamly difficult to start after a long high speed run. It starts easily cold and if it is immediately re-started after a run, but will not start if it is left to cool for between 10 mins and 2 hrs. Cranks fine. Runs great the rest of the time. Plugs are getting spark, carb is getting gas (accelerator pump - pumps gas). I have replaced plugs, points, condensor and coil. Leads are fairly new. Coil is getting a full 12V while cranking. Compression is 95psi on all 4 pots.
Someone suggested it could be vapor lock but as the accelerator pump squirts gas not vapor I don't think it could be. Also even after 1-2hrs of cooling off it still wont start. Leave it another couple of hours and it starts fine. One thing I noticed is that there is a fair amount of water (condensation ?) in the intake manifold after a run.
Any suggestions welcome.
