Omc cobra 5.0 heads
jcdubbu
Looking into rebuilding my 302 in a 95 seaswirl spyder. Was told that it has 351 heads on it from the factory. Was wondering if anyone knew if this was true. Thanks in advance
And some use the 302 crank, some use the 351 crank (different firing orders). This is important if you get a new cam
skippy2235
My 1993 351W cobra came with factory GT40 heads.
I did not know at the time, but learned, they are a prized item to have.
The shop that re-built them was quit impressed and loved working on them.
I still dont understand why.
jcdubbu
Guess I'll have to do some in depth research before I go ordering a master rebuild kit...thanks
You will always do well if you have a knowledgeable machine shop
vasy
I got 1995 Seaswirl as well and on my motor the firing order sticker indicated 1-3-7 which is indication of the motor at least having a 351 crank.
I dunno about the heads though.
