Re: OMC Cobra 88 help newbie
You lined-up good on the shift-fork?, don't see how you couldn't be, but you did mess with the cable. Just thinking... Did the bellows rip at the opening (not the clamp end)?? My guess would be yes.
Just remembererd this too, found this out the hard-way. The nose of the boat has to be as low as possible, if you have a tounge-jack, it will not go low enough. I put mine on a floor-jack about 6 ft aft on the trailer and put the coupling on the ground, jack folded-up. This way you go straight-in and the joiner between the U-joints does not try to "Kink" on ya. This method, for me, makes the R&R easy. I fought mine the first try until I figured that one out.
You check your alignment??? Sagging motor-mounts will keep the shaft from going back also. It'll come out, but won't go back....Ask me how I know.......
