Omc cobra drive / engine noise
Cplatipodis
https://youtu.be/hLOYzzkDqCE Watch the video. I ended up replacing the upper unit on my omc cobra rear dive. I now have a new noise which I'm assuming has something to do with the engine not being aligned to the drive . Just want to get your opinions. Mod EDIT: Email address removed Thanks in advance CP
southkogs
Assuming the engine doesn't do that when the drive is not attached, I would agree with you that it sounds like an alignment issue. Dunno' much about the Cobra's, but did you align it when you installed it?
Cplatipodis
Actually the more research I do im finding it may be a spindle bearing. Going to have to pull the drive and find out .
jbcurt00
Please keep the discussion in the forum, email addy removed.
Privately via email doesnt help anyone else w a similar problem.
