Don't Panic!
- Oct 3, 2019
- 57
Hi all,
I've done a ton of reading here and elsewhere, and feel ready to dive in to this 18' SeaRay Seville bowrider with an OMC 4.3 Cobra. I'm not sure of the year, but it's around 1987 +/- a year. With 380 hrs on it and presumably stored dry, it looks to be in great shape. No damage to the interior, no soft spots, ski locker is dry and clean. I am gathering that most of these era SeaRay's are rotten messes, I'm hoping I've got the exception lol.
I don't have a ton of history on it, but the fuel separator and oil filter are marked 2018, and the distributor cap 2001 (sharpie on the sides of all). Still has points ignition
. It seems to run very well.
Here is my plan of attack:
- replace all rubber fuel and coolant lines (I see visible cracking on the fuel tank vent line)
- new cap/rotor/points/condenser
- replace belts
- change oil and filter
- pull batwings (yes it still has them, and I assume they are the originals) and do acetone test.
- pull outdrive and inspect bellows/o-rings.
- replace waterpump in outdrive
- separate lower unit and check shifter height
- set shift cable adjustment (already ordered the tools for that)
- inspect everything, replace as needed, and reassemble.
I know I'll need an alignment tool to check/set alignment of the outdrive, but I am going to wait on ordering that to see if I need a gimble bearing and bellows too. I figure I'll do all disassembly then order everything at once. Except the shift cable adjustment tool, that I ordered already cause I got a little excited.
I got it in my garage (no small feat!) and plan to dive in tomorrow.
- replace belts
