OMC cobra gearbox problem
jacko141
Hi All i have a OMC cobra 5.8l an stern drive unit , it appears to have developed a flat spot in the engine at the same time the gear box is stalling when going into gear and now apparently stuck in forward . people are saying things like shift cable , and vacuum assist issues please help, Perth Australia refuses to work on Cobra,s
jerryjerry05
Re: OMC cobra gearbox problem
Stalling going into gear could be a cable,Could be a shift interupt switch.Or the bellcrank.Get a parts diagram.
I'd start with the cable first.Remove the drive.The shift mechanism is on the right.It's called the bellcrank,it gets gummed up and won't move right.Take it apart.Remember how it came apart.Check the shifter for the cable if it's working right.Load it with grease and re-assemble.Try this,it might help.Jerry
HT32BSX115
Howdy,
Please be more specific on the year, model and series.
Depending on the year model, there's 2 different Cobra types that were used with the FORD 5.8L engine.
Sorry about that, this is becoming more and more the "rule" instead of the "exception"......
jacko141
Thanks Jerry , was in fact a faulty shift cable , have got a new one but im having trouble removing it from the gymbal housing any ideas
cheers
mike
Joshua Nichols
You should have a look here
http://www.hastings.org/~stuart/cobra/
A good read
The cable runs though a sleeve... You have removed the outdrive right?:confused:
I recommend you post the year of your set up and engine type in your profile signature.. Makes getting answers a bit easier..
I am so grateful that when they installed my engine and outdrive from the factory that they left the gauges they use to get it right in a folder and the PO kept all that stuff..
Makes it real nice and takes a lot of guess work out of adjustment...
Good luck bud
