Boating this past weekend,Reverse stopped engaging,Goes into forward fine.Tried adjusting the lower shift cable ,was able to get reverse but then I couldn't get forward.Wondering if this would be the lower shift cable getting worn out.
If you have the new cable, I would change it now. Why risk a blown gearcase for a few hours work? And yes, the shift cables on Cobra drives do need periodic adjustments. Like yearly. If you're lucky. It's what makes Cobra drives a pita. But, you learn to live with it, or you get rid of it.It's a 89 renken 3ltr ,cobra outdrive.I've owned it about 4 years,previous owner had it serviced at a shop.It has always been kinda hard to shift but always went into gear no prob.The last time I lost rev I removed the lower cable at the motor end and pushed it from forward to rev a bunch of times reattached it and it worked fine again for about 30 hrs ,now same issue.There has never been any grinding of the gears since I've owned the boat.I read the info about the problem it seems to be common.I'm going to go and check the color of the cable.Do these need adjusting over time?I do have a new cable so if I can make it till the end of the year I'll pull the drive and change it then.
Because it's cheap insurance, that's why. Look up the cost of a new gearset for that drive. His cable may be past the point where an adjustment will solve the problem. And he didn't say anything about the cable being "pigtailed", or salt in the bellcrank area. He can do the adjustment, hit the water & it may shift fine. Or he can do the adjustment, hit the water & blow the drive because the cable is shot. I suggested he change the cable now because he has one on hand anyway. Those cables are no fun to change. But neither is emptying your wallet on a new gearset or replacement drive. If he changes the cable now, & follows the steps in the Hastings site, his drive will shift with one finger. Problem solved.Why O' why, would you change the cable prior to knowing IF the cable was the cause of your problem??/ No doubt you can benifit from all a new cable brings to the table, but perhaps a build up of salt in the bell-crank area, as an example, really is the cause of you issues.... What if the cable is "pig-tailed" due to the fact that the previous mechanic didn't install the webbing around the cable when he installed it.., Hense, causing the cable to be damaged. A "new cable" reinstalled just like the old cable will fail again...
So, what is the failure, the cause, and what's it gunna take to fix it !!?? BTW, Cobra's are very good units, it's just that most have never taken the time to DO IT RIGHT the first time!!
So, has the cable failed? Is the correct vertical shift arm installed??
