omc cobra outdrive gaskets come with 2 mystery o rings
davidonmars
So i got these 2 o rings that came with the gasket set and I'm not quite sure what these used for? All I used was the gasket a this other rubber ring not circular but i thinkit sits around the water outlet. Any idea what these 2 o-rings are for? Thanks
lynnboy021
Re: omc cobra outdrive gaskets come with 2 mystery o rings
the 2 o-rings go on your outdrive shaft.
Lou C
Yes they do go on the driveshaft and make sure you lube them with a little motor oil before installing....
