OMC Cobra Outdrive question
lakenormangal
I have a 4.3 v6 Cobra. The outdrive is shot ( someone did a patch job on the case years before I got it and the patch gave it up on the lake one day and well, now the whole thing is toast. BTW, they put a ton of paint on it and neither me or the previous owner had any idea it was there.)
Shopping for a replacement and finding a few outdrives for 3.0 Cobras. Is it the same unit? Or is a 4.3 a different unit.
Thanks.
Ayuh,.... Even if another Cobra, the gear ratios are very different, 'n it won't work,...
Lou C
The upper gear housings are the same but the lowers are different up to 90/91. Early 3.0s had a lighter duty lower that was eventually changed for the same one used on the V6/V8s.
And yes the gear ratios would be wrong for the 4.3.
