Re: OMC cobra problems again.
I thought all of those were cone clutches.
The (big one behind the 460) Dog-Clutch Cobras were from 87-89. (Mine was an 87 model)
In 90 they discontinued the Dog-clutch model for the 460 and offered the "new' Cone-clutch model for both the 460 and 454..........but kept the smaller dog-clutch models for a while...... I also think 90 was when they started calling Other-than (BBC/BBF drives) "King" Cobra.......(like the 5.8L King Cobra.......which is a Cone)
This Cone clutch model 90 to about 95 or so, Is also the one that is NOT a Volvo SX (which makes it the "Interim" OMC drive.........BEFORE the Volvo OMC joint "thang" ) .......I think the (Cobra) SX was 96 (95 & 1/2) and later?
If he had a 90 (Big-Block) Cone Clutch Cobra he'd be even more up a creek........The raw water impellers are evidently VERY hard to find as are other parts..................
The good thing is that there's some parts out there for the "Big-Dog"........Clutch dogs and gear-sets are still around......T.C. Electronics still will rebuild them as will others.... And (for the 460) there's Couplers and manifolds available (for the time being).........
GET'EM While they're HOT!!!!
If your clutch dogs are NOT damaged, your problem is most likely a lower shift cable problem (defective, adjustment, etc) or a bent shift shaft.
Make sure your idle RPM is correct (600-650 I think) and ENSURE that your ESA works correctly or it will be VERY hard to get out of gear (FWD/REV) and you'll damage the lower shift cable quickly.
GET A SERVICE MANUAL! And if you drain and refill the drive with oil.........DO IT IAW the service manual or you will destroy the drive!
(I am beginning to think I am a broken record!!!
Cheers,
Rick
