I have a 1992 OMC 3.0L with a cobra sterndrive. I currently run a 15x17 aluminum propeller, part number 391200. I found a stainless steel prop on e-bay, which according to the parts list, should be the correct upgrade, part number 391290. However, there is a difference in the prop hubs. There is a greater distance between the back face of the prop and the hub on the aluminum prop. When the aluminum prop is mounted the thrust bushing fully seats into the prop, when mounting the stainless prop there is not enough clearance for the bushing to fully seat into the prop, however, the thrust bushing does appear to align to the hub and inserts approximately the depth of the chamfer when torqued to the proper amount. When rotating the prop it feels secure, but I am still concerned about these differences and what will happen when I am at high speed. Any body out there aware of this? Your help is appreciated. Thanks.
