OMC Cobra Prop
79Rude115
What props will fit a 90 5.7 Cobra? Will a prop from a Mercruiser Alpha One fit?
Dhadley
Re: OMC Cobra Prop
That Cobra should have the 15 spline propshaft. If so, any OMC / Evinrude / Johnson prop with a 15 spline hub will fit right on. If you get a new style prop with a square bore you can get the correct hub kit and you'll be all set. The Merc props won't go on without some modifying.
79Rude115
Re: OMC Cobra Prop
Thanks! Is the Merc a different spline count or something else? I ask because I have a guy who is selling one, he says from a Alpha One, said it is a 15 tooth spline.
Re: OMC Cobra Prop
Nope,... It's spline Depth...along the propshaft...
