Re: OMC Cobra Tilt
The trim pump should be mounted on the port side next to the engine against the transom.
It should be a 2 wire system,(green and blue) The connection about 4 foot from the pump is a plastic connector. Start by finding that and cleaning the connections.
You can also jump power direct from the battery to those 2 wires and see if the pump runs.
+ to the green wire and - to the blue and it should raise the drive.
Reverse polarity and it should lower.
That will tell you if the pump is working or if you have a wiring,switch or solenoid problem.
Also there are 2 50 amp fuses inside black rubber boots just to the left side top of the engine usually near the shift cable bracket.One fuse is for the trim system.
If you have the black plastic OMC throttle control with the red trim button those are known to fail.
