OMC Cobra water pump
highrocklake
Vmax,
I have a 1987 omc cobra 3.0 on which I have replaced circulation pump, thermostat, Impeller twice. My problem is It doesn,t seem to pick up water to impeller. I don't mind doing the work but there is a complete lack of video on Youtube about the process and the Manuel is very vague. Any helpfull hints on removing the foot to inspect the screen or water pickup tube?
Ayuh,..... I gave you a thread of yer own, rather than the 20 year old thread you hy-jacked,....
How are you feeding water to the drive,..??
A big bucket won't work,....
You need a quality set of muffs,.....
welcome aboard.
as indicated, if trying to suck from a bucket, you will just burn up the impeller. you need muffs. if you want to use a bucket, get a bucket big enough to put the whole boat in it so the impeller starts with water 8" above it to prime the pump.
factory manual is a great thing. if you are using a clymer, Haynes or seloc manual, they are not worth the paper they were printed on.
OMC went out of business long before youtube was a thing
