omc cobra
88stratos
i bought a 88 stratos ski boat with a 4.3 V6 and omc cobra outdrive and it wouldnt go in reverse and finally did when i pulled the linkage back now its stuck in reverse any ideas on what it could be
88stratos
Re: omc cobra
howdy, thats what we were thinking but also when you pull the lower drive is there any tricks to getting it out because it WOULD not come out and it got dark so we quit for today and i dont beleive it was sealed good or something because there was definately some water in there......thanks
HT32BSX115
Re: omc cobra
There's 6 steel nuts on the drive to remove and the long SS rod thru the back holding the trim cyls on.
remove them and it should slide right off. If it doesn't come off, the yoke may be stuck in the coupler (because it hasn't been removed in a long time) It will be very hard to pull off.
(I hope you didn't pay a lot for this boat......)
Were you able to move it at all?
88stratos
Re: omc cobra
yeah it came down about an inch and wouldnt go any further we wiggled it and twisted it, but didnt want to force it to come off because neither me or my buddy are mechanics so i didnt wanna make it worse somehow
slasmith1
Re: omc cobra
came down or out?
HT32BSX115
Re: omc cobra
The only thing holding the yoke in there then is probably the gimbal bearing. There's probably some corrosion on the yoke shaft and it getting caught on the bearing.
If you got it out an inch or so you should be able to see the U-joints.
Are they all rusty?
You're probably going to need to replace them, the gimbal bearing, bellows, shift cable, bellows, etc...
88stratos
Re: omc cobra
Are they all rusty?
couldnt really see a whole lot like i said it was getting dark.so how will i get it out. how expensive are we talking for parts...oh and when you said hope you didnt pay alot? yeah ive already heard that i might have gotten in trouble with this one....first boat...over anxious to buy!!!
sea wolf
Re: omc cobra
Try to squirt some PB Blaster inside there & let is soak for awhile. Like HT said, plan on replacing u-joints, etc. If u buy the parts on ebay, you're looking at approx. $150.00., or iboats will have what you need. You need an OMC shop manuel if u plan on doing the work yourself.
Gary H NC
Re: omc cobra
Transom service kit is about 125 at ebasicpower.
That includes the gasket,seals,o-rings,bellows and gimbal bearing.
The u-joints and shift cable will run another 150 to 200....
Might as well do it all while its apart...
The OEM service manual is a MUST have for this job....the shift cable adjustment must be done to exact specs in the manual.
This is the real manual,The Seloc or Clymers books are useless..
Also the drive should be in forward gear when pulling it..turn the prop to make sure the clutch dogs are in gear.
http://cgi.ebay.com/ebaymotors/1988...e?hash=item2ea54caad8&_trksid=p4506.m20.l1116
88stratos
Re: omc cobra
okay well thanks alot for everyones input.....im gonna start ordering some stuff and i will keep you posted......guess i wont be on the water this weekend anyway!! oh yeah and if its stuck in reverse and has to be in forward to pull it apart??????????????????????????????????????????????how do i get it out of reverse
sea wolf
Re: omc cobra
Well, there's 2 ways. You can remove the shift cable at the engine, & pull on the cable to get it back into neutral. Or, remove the front anode & raise the shift rod.
88stratos
Re: omc cobra
which way is the easiest............well i guess it would be the first way you said considering i dont know what the front anode is???? very new to the whole boating thing other than driving someone elses boat at the lake just never owned one...thanks
sea wolf
Re: omc cobra
Never mind the anode. Try to shift it at the engine.
HT32BSX115
Re: omc cobra
It really doesn't matter what gear it's in to remove it. (It's a Cobra) It just has to be in the same position when it goes back on.
bruceb58
Re: omc cobra
The only way that is going to work is if you are going to be able to get it on the shaft as it goes through the gimbal bearing.
My suggestion is push it back in the inch and then pull it out again. If you work it back and forth, it will come out. Getting it out an inch is a very good sign you will be able to get it out.
Another trick is to attach the trim cylinders back up and stand on the drive while some one hits the up button on the trim.
sea wolf
Re: omc cobra
You know, you're right. I've always pulled mine while it was in neutral. Now I feel bad for giving the guy bad advice.
