I just purchased a 1989 inboard/outboard (sterndrive) boat. It won't idle. I have limited knowledge about boats but minor knowledge on car engines. So, i thought i would have a look. It appears that the idle screw is slipping on the plate. If i set the screw off to where it idles properlly it works fine until i put it into gear. Then the screw doesn't hold and the carb closes up and the engine dies. If i screw the idle screw in the whole way so it is tight and won't slip, it idles fine but it idles at a very high rpm. Any ideas why this might not be holding the idle properlly? or why it is slipping?
Please help,
thanks!!!
Please help,
thanks!!!
