omc float gauge
Stevet1984
Does anyone have the measurements for one of these? i would like to make sure that all my floats are correctly positioned?
I know that they should be parallel with the carb when turned upside down but how big should the gap be between the carb and the float?
Thanks
Steve
tashasdaddy
Re: omc float gauge
look at the hinged side, then the other, i personally like just the slightest more space on the free side of the float. never use the measurement guide. after reassembly, connect a clean piece of hose to carb, carb right side up, you should be able to blow air thru the carb, upside down, no flow.
