Galaxie1989
- May 3, 2013
- 19
I have a 1987 Omc ford 2.3l I have been working on the past few months. It was previously parked in a friends yard for a couple years but ran fine before,Besides the cosmetics I have replaced : starter, alternator, wiring, ,ignition.plugs, coil, and bought a used distributor. So the boat was running great. Id run it on muffs for an hour or so every now and then about a dozen times (while I started replacing deck and seats) So I start it at the house with muffs a couple weeks ago and It runs poorly, wont idle without dying out. So i check the oil level and it is high. I pulled the filter and the oil is really thin and smells like gas. Oil level is probably about a quart or so full of gasoline. other symptoms were the spark plugs looked black and for what i would assume would be an unrelated issue the new alternator doesn't seem to be keeping battery charged, so if anyone has a wiring diagram or something on that. But anyway, I read the threads and have replaced the the fuel pump with no luck so I just ordered a carb kit , will be my first rebuild so tips please. I also ordered new gaskets for intake/exhaust manifold because they appear to be in bad shape. If anyone has any experience/knowledge/advice/or ideas id appreciate any input .
