OMC / Four Winns Shift Cable
79Rude115
Does anyone know where I can find a part number for a upper shift cable and throttle cable for a 1990 Four Winns Horizon 200 with OMC 5.7?
HT32BSX115
Re: OMC / Four Winns Shift Cable
Howdy,
It appears that you're replacing the (2) shift & throttle cables from your shift/throttle control to the engine.
More than likely, you have Teleflex cables running from the control to the shift bracket and carb.....
Once you get the cables removed from the shift quadrant, you should be able to read the numbers on them. If they're NOT Teleflex cables, you can measure them and order them from multiple dealers including right here on iBoats..... I got mine from Wholesale Marine.
Regards,
Rick
