I have a 95 ChrisCraft with a 4.3 VolvoPenta/ OMC engine with an electric fuel pump. I am having an occasional problem that i need advice about. The boat will always start right of the trailer,but after a few minutes of running the engine will die. The carb. will be dry and no fuel being pumped through the line. I can start the engine up with carbcleaner and after about a half a can later the engine will run on it's own, I will not have any more problems starting the engine the rest of the day and the engine doesnt skip a bit.It seems to me that the fuel pump is loosing its prime after the boat sits up for awhile. I dont have this problem if I use the boat every day. I was told that there is a check valve in the fuel pump that can leak down and cause this problem. I dont think it is electrical because the boat will run fine all day after getting it started. Has anyone had this type of problem before? How can I be sure it is the fuel pump? Thanks for any Help!
