OMC HP
inthegulf
I have seadrives 1.6 liter (1985) I one with a flat exhaust cover and one with a bubble exhaust cover back. What would the difference be? Also when I look in the books it seems hp on the V4's range 100-140 with basicly the same bore and stroke, where is the different hp coming from compression or carbs? thanks
jegervais
Re: OMC HP
The differences in hp typically comes from differences in porting, carburetion (jetting & venturi diameter) and exhaust tuning.<br /><br />Can you post the model numbers from both engines?<br /><br />-John
