Re: OMC I/O?
I think my 69 omc I/O is fantastic ive had mine since 1998 all they need is some TLC, and drop the gear oil alot. i find you have just as much trouble with any old boat electic shift or mechanical read the fourum, i have replaced water pump tilt cyliniods tilt motor engine belt fuel pump distributor points cap rotor wires, plugs yearly oil change yearly, fuel tank, fuel filters,
pulled my tilt motor 3 times, got that down to a science, i have never had water in engine oil or cylindars, my baby starts on the firt crank all the time, as long as im getting fuel im moving i never had a tow in 8 years although i did go 2 miles in reverse, even with a slipping hub i can move, my boat is clen and ship shape, and i get some really weird looks and compliments from those who know and understand that boating is a lot fo f___ing work.
p.s. no one will touch your boat with a 10 foot barge pole if you need someone to work on it!
