I have been reading some related posts to this problem that are similiar to mine. 1987 OMC 5.7 engine starts fine. Turn off key then stops. If I keep key on then motor gets spark.Turn key off runs then dies. I assume it is the resister somewhere in the wiring that cuts the voltage from 12 to 9. A direct lead from the + battery to the coil will keep the motor running. However all this voltage gets the coil red hot. <br />I cannot find where the resister is!!! to bypass it.I have ordered a OMC manual and hope that pinpoints the location.<br />Does anyone know the location or if I am on the right track here? Two mechanics have told me to bypass the resister and the bypass from the battery to the coil does indicate the resister is bad...but cannot find it to bypass or replace.<br />Thanks in advance.
