ineedabrew
- Jul 7, 2017
- 20
Ok everybody,
My tilt on my OMC (HU 16C) inboard/ouboard got stuck in up position. After research and plenty of help from this site (THANK YOU!), I pulled the clutch housing apart to find bits of the worm gear shaft pins that sheared off. My question is, Can I just replace the spring pin that was in there? I understand this is designed to fail here rather than somewhere else so I don't want to cause more problems if I do this.
What do you guys and gals think?
Thanks!
Thanks!
