OMC Johnson Evinrude service bulletins
clanton
Re: OMC Johnson Evinrude service bulletins
Which one are you looking for?
reddog23
I would like to have the ones that apply to my 1986 225 johnson. I have tried to get them from OMC first,then bombardier to no avail. It's like they want to keep them a secret. I would think they would want to get the info out and help their customers.<br />I hope you have a source....<br /> thanks<br /><br /> Reddog
clanton
If you identify a problem, I will look a for a bulletin that may cover it. The thermostats and seats were changed. Some of these engines had idling problems and the carbs were changed to a smaller bore carb, which is same carb as 1987 engine. The VRO pump and warning system changed. The VRO pump kit was avalable to the orginal owner<br />in 1989 for 69.95 US. There were a lot of changes to later engines, but do not apply to your engine.
reddog23
Thanks a lot...my engine is actually a 1987 225.i guess i was typing to fast. I am specifically looking for any info about rejetting the carb.Were there any sb on the carbs of the 1987?<br />thanks again<br />reddog
clanton
Do not find anything about rejetting carbs for 87 225. Why do you want to rejet?
wilde1j
Clanton, I was looking for an on-line resource like the Mercruiser stuff which can be accessed on line.<br />Jim
