OMC Johnson Pressurized Fuel Tank
joeyb1180
I just took apart my tank to change the gaskets, with some elbow grease to get it apart, a spring, a small rubber top hat looking thing, and a metal washer fell out without me seeing where they came from, anybody know where I can find and explosion chart, or a repair manual for pressurized fuel tanks? Even better, can anybody help me over this forum? Thank you all for your time and help. joeyb1180@aol.com
pungolee
Re: OMC Johnson Pressurized Fuel Tank
one spring goes under the air relief valve(a solid disc the size of a nickle the top hat)One spring goes on top of the diaphram where the plunger shaft connects to the diaphram.You have a small solid disc between this and the air relief valve.There are no washers(with hole in center)except the ones for the screws.Seloc manual 1/johnson evinrude 1.5 to 40 hp has step by step instructions with pictures.
JB
Moving to General Outboard.
alcan
Hi Joey<br />Check your e-mail.
