Re: Omc Johnson Warning Module Wiring Diagram Help
Well,
I am very surprised that it didn't start right up.
But, since you have been working on the control side of the wiring harness, is it possible that you accidentally shorted +12v to the black/yellow wire up at the key switch? If so, you can blow the power pack from that type of error.
I guess if it were me, I would replace the PP now.
Again, it will run with the harness disconnected, so try to get it running like that to eliminate ANY control harness problems. Leave that black/yellow disconnected at the new pack also, just in case you have a +12v short on that wire. That will keep you from blowing a new pack. Plug it back only when you are sure it is NOT shorted to any voltage source.
Key on, harness plugged in, black/yellow unplugged at the pack, engine not running, measure the voltage to ground from the harness side (not the pack side) of the black/yellow wire.
No voltage is allowed....zero volts is correct. Maybe switch the key on and off (jiggle the key) with the meter still connected, to make sure that the black/yellow wire NEVER has any voltage on it.
