OMC Knowledge needed
commonarcwelder
Hi all. I need to know what years lower units will fit a 1996 Evinrude 225 ? Will a 150 fit a 225 etc.. In your opinion which is the strongest that will fit. I have what is believed to be an 86 and another believed to be a 76 model. Looks like the same bolt-up? Thanks for the help in advance!
Faztbullet
Re: OMC Knowledge needed
V-6 units will interchange from 1976-2002. The only differences are:
Early style housing had 4 bolts to hold carrier in place retained by snap rings.
Later model uses 2 bolts and tabs.
89-95 use a smaller propshaft ( 1.187)
96 and up use a 1.250 propshaft so reverse gear is different.
Drive shaft lengths are different because of crankshafts lengths
Early units use 1 piece driveshafts as newer use 2 piece shafts
The best for the buck if your not running a chopper is the 89 and up units. if running a sufacing prop swap guts to the magnum housing (beefier)
commonarcwelder
Thanks for the reply!!! That is good news! Now for my next question....Can I replace the old 1 piece shaft with my 2 piece so it will fit my crankshaft length? BTW...What is this Magnum housing you speak of? Thanks, Keith
commonarcwelder
Thanks for the move TashasDaddy......Must've been lost. Keith
Faztbullet
yes!! you can replace a 1 piece with a 2 piece Here is a picture of magnum housing,
commonarcwelder
Thanks for the input fazt......So the Magnum housing wasnt just a specific year or years?
Faztbullet
You started seeing this housing in 01 and up engines. It will backdate to early models.
