OMC Lower Unit Seal Kit Question.......
EL-BATO
bought the following seal kit prior to winterizing: http://www.iboats.com/mall/partfind...&gd_poid=109185&gd_row=5&session_id=391475158
While changing the gear lube in an '88 (OMC 3.0L) Cobra outdrive I was hoping to change the little rubber seals on each of the upper(dipstick), mid (filler), lower (drain) and water drain (port side) plugs but couldn't for the life of me find any matching replacement seals in the kit...!? Am I going crazy here or are these seals not included?
If so, then does anyone know which seal kit has those?
Thanks!
bruceb58
